I’m trying to validate storage configuration (specifically Azure) in isolation, using a “minimal” Loki instance running in a Docker container. I’m using the “local” config file provided in the “Install Loki with Docker or Docker Compose” documentation, here, and then modifying it with Azure storage configuration, shown below.
I’m having trouble validating that the configuration works. The behavior I’m seeing doesn’t match my expectations, and so before digging deeper I need to validate that my expectations are correct. Here’s my test:
- Start the Loki container:
docker run --name loki -v .:/mnt/config -p 3100:3100 grafana/loki:3.0.0 --config.file=/mnt/config/loki-config.yaml
curl http://localhost:3100/ready
until the response isready
curl -X POST http://localhost:3100/loki/api/v1/push -H "Content-Type: application/json" -d @log.json
where log.json has a log payload containing entries with timestamps from around now: e.g.
"streams": [
"stream": {
"label": "foo"
"values": [
[ "1727285016000000000", "Foo bar baz" ],
[ "1727285016000000001", "Biz baz boz" ]
curl -G -s "http://localhost:3100/loki/api/v1/query" --data-urlencode 'query=sum(rate({label="foo"}[90m])) by (level)' | jq > query.json
and verify that my push is reflected in the results.- Verify no errors written in the output of the Docker container.
- Stop the container, delete it, and recreate. Wait for it to be ready, and re-query.
Expected:
The query after the recreate returns similar results (because the logs were persisted).
Actual:
The query after the recreate doesn’t return any entries/lines. Additionally, the only thing in the Blob storage container is a loki_cluster_seed.json
file, with a size of 251 bytes that never changes.
Provisional Conclusion:
Loki is not configured correctly for persisting logs.
Configuration:
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
azure:
account_key: <key>
account_name: <account name>
container_name: loki
request_timeout: 0
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: azure
schema: v13
store: tsdb
storage_config:
tsdb_shipper:
active_index_directory: /tmp/loki/tsdb-index
cache_location: /tmp/loki/tsdb-cache
ruler:
alertmanager_url: http://localhost:9093
I’ve also performed the same test with the common.storage.azure object defined in storage_config instead, with the same results.
