I have a serach that looks or gives output as follows:
How does grafana handle this?
this is what I have got so far
but I am not sure what grafana is doing.
is it getting the max rssi, or is it just picking out one gateway value?
7.5.7
- What are you trying to achieve?
understand how grafana hanles json object
- How are you trying to achieve it?
as above
What happened?
