Hi everyone,
I’m working with numerical data and trying to find a simple way to understand percentage changes between different values. For example, when comparing two measurements on a dashboard, I sometimes need to calculate how much a value has increased or decreased as a percentage.
The basic formula is:
Percentage Change = ((New Value - Old Value) / Old Value) × 100
However, I was wondering how others handle these calculations in Grafana dashboards. Do you usually create expressions directly in Grafana, use transformations, or calculate percentages before sending the data to your dashboard?
I’d be interested in hearing which approach works best, especially when working with changing metrics and avoiding calculation errors.
For occasional manual calculations, an online percentage off calculator can also be useful for checking percentage differences and discount calculations.
Thanks for sharing your suggestions!
