Hi, I am currently setting up Grafana + Prometheus + resilience4j. I am using v7.4.3 of Grafana and I have multiple circuit breakers from several test servers. (Resilience4j)
I am trying to make an alert that sends webhook when there is a change in the state of the circuit breaker. (open to close/close to open)
From my understanding, to achieve this, I need to use “AND” in the alert conditions. (since I need to check the change in the state from previous state to current)
However, I have several problems:
- In the webhook, in the “evalMatches”, I receive all values that exist which includes all the ones should have failed to pass the condition.
- Trigger for “close to open” is always triggered when the state changes from “open to close”
- The trigger doesn’t send another alarm when another circuit becomes open. (so alarm gets send only once a single circuit is opened but ignores the next opened one) I am expecting each alarm to be sent when each circuit breaker is opened. (if a several circuits are opened at the same time, then they should be in a single webhook)
Can anyone tell me what is the problem in the setting?
For open alert (from close to open) (graph + query + alert setting),
For closed alert (open to close) (graph + query + alert setting),
I am stuck here for several hours trying to configure how to set this up…
Probably I am trying to do something that is not supported or there is any lack of explanation, please let me know as well!
Thank you anyone who can help me in advance!
