Latest Grafana version and Windows 10 -
I want to create an attendance table for a school where I want to show when a student enters the school premises and leaves using a table. The first row of the table should contain the hours of the day and the first column should the dates (25 columns - 1 col for date, 24- cols for hours in a day). I have attached picture of the table that I want to create. -
I am thinking about using heatmap, but I am not sure about it. -
What happened?
This is the image of the table that I want to create.
Let me know if you know about a plugin that will help me to create it or a way to do so.
Thank you
