I wonder how Grafana Cloud users capture resource utilization metrics?
Is it achieved by deploying a Prometheus scraping kubelet/cadvisor or does Grafana Metrics Agent support this use case already?
Thanks,
Teja
Thanks,
Teja
Hi Teja! What kind of resource utilization are you interested in capturing? As you mentioned, the Grafana Agent + integrations are able to scrape and export metrics specific to the OS or application they were built for. If you haven’t already seen the Kubernetes Integration, I recommend checking it out as it was designed to collect resource usage and operations in a Kubernetes cluster.
Hi Melody!
I would like to capture the resource utilization metrics of my application deployed in a specific namespace. In regular k8s, we have metrics coming from cadvisor for each container, PVC and POD. Not interested to monitor the complete k8s infrastructure but maybe node-level metrics from a node monitoring agent like node exporter. Do you get the idea?!
