How can show timeline on X Axis char
I have created a barchart dashboard such as attached pic and the time is 13:00 and is showing some items with value in that time . now want it shows another in 13:01 and don’t want replace firs one I want to show and keep both of them I want to have a timeline but it is just updating and don’t show previous time
Hi @alex23
If you put a value (e.g. 2m) in the Relative Time box under Query Options, then the value in the time picker will be overridden and the graph will always display the past 2 minutes of data.
