v11.0.0, MacOS Sonoma -
Make it so that the Lambda metric interval start time is at a consistent time in the hour. e.g. For a 15min interval, the tooltip should show at [15:00, 15:15, 15:30, 15:45, 16:00] not [15:02, 15:17, 15:32, 15:47, 16:02] like in the image.
Play around with query options. I’m not sure what these mean.
What happened?
When I load the relevant dashboard, it shows the values at the current time with an interval of 15min historically. I.e. If I view the dashboard at 9:24, the values I get in the panel in the tooltips are 9:24, 9:09, 8:54 … -
I expect the earliest metric I can see to be 9:15, going back to 9:00, 8:45 … -
"datasource": {
"type": "cloudwatch",
"uid": "------------"
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "line",
"lineInterpolation": "linear",
"barAlignment": 0,
"lineWidth": 1,
"fillOpacity": 0,
"gradientMode": "none",
"spanNulls": false,
"insertNulls": false,
"showPoints": "auto",
"pointSize": 5,
"stacking": {
"mode": "none",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"axisBorderShow": false,
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [
"matcher": {
"id": "byName",
"options": "Duration"
"properties": [
"id": "custom.axisPlacement",
"value": "right"
"id": "unit",
"value": "ms"
"gridPos": {
"h": 8,
"w": 8,
"x": 16,
"y": 8
"id": 6,
"options": {
"tooltip": {
"mode": "multi",
"sort": "none",
"maxHeight": 600
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
"timezone": [
"browser"
"targets": [
"datasource": {
"uid": "----------"
"dimensions": {
"FunctionName": "---------"
"expression": "",
"hide": false,
"id": "i",
"label": "Invocations",
"logGroups": [],
"matchExact": true,
"metricEditorMode": 0,
"metricName": "Invocations",
"metricQueryType": 0,
"namespace": "AWS/Lambda",
"period": "900",
"queryMode": "Metrics",
"refId": "A",
"region": "---------",
"sqlExpression": "",
"statistic": "Sum"
"datasource": {
"uid": "----------"
"dimensions": {
"FunctionName": "-------"
"expression": "",
"hide": false,
"id": "d",
"label": "Duration",
"logGroups": [],
"matchExact": true,
"metricName": "Duration",
"period": "900",
"refId": "B",
"region": "------",
"statistic": "Maximum"
"title": "Load Control Requests",
"type": "timeseries"
