8.3.1 on Linux -
I’m trying to use a button plugin to make an HTTP request to a web server running on the same computer as the Grafana server. Users can view the dashboard locally or remotely, so I can’t just POST to “https://localhost/…” since that won’t resolve properly when viewing the dashboard remotely.
I’m trying to figure out how to get the hostname portion of the browser URL into a dashboard variable. Then I can put that variable into the URL for the button, and the button will work wherever the user accesses the dashboard from.
Getting the hostname from Grafana isn’t a solution since it will always be the same. I want to get the hostname from the browser, in the same way that window.location.hostname
would in JavaScript.
Is there any way to do this in Grafana, either natively or using a third-party plugin?
Thanks!
