slhck
June 17, 2026, 9:32am
1
What Grafana version and what operating system are you using? 13.0.2
What are you trying to achieve? I want a query variable that lists all unique values from an Elasticsearch index, e.g. “give me all unique hostnames” for a filter
I have previously used this type of query:
{"find": "terms", "field": "client.extra_label.keyword" }
This would give me all client labels.
I now see this window, but where am I supposed to enter the query?
I expected to be able to just … query the unique labels as before?
Can you copy/paste the configuration(s) that you are having problems with? N/A
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. N/A
Did you follow any online instructions? If so, what is the URL? I could not find any documentation matching this feature
The query
{"find":"terms","field":"client.extra_label.keyword"}
returns the unique values of client.extra_label.keyword using an Elasticsearch terms aggregation.
Could you confirm:
Which Elasticsearch datasource version you’re using?
Whether this variable was created from scratch or migrated from an older Grafana version?
That information help determine how the legacy find: "terms" query maps to the current variable editor.
slhck
June 17, 2026, 12:56pm
3
How do I find out? I am just using the Docker image for 13.0.2 as-is.
This “legacy” variable was migrated over from 12.x to 13.x.
slhck
June 17, 2026, 12:57pm
4
PS: I have filed an issue here: Dashboards: Cannot query unique values using Elasticsearch raw query · Issue #126663 · grafana/grafana · GitHub
There are multiple things going on, I think, apart from not being able to just re-use the old type of query.
slhck
June 17, 2026, 1:51pm
5
Ok, that was more complicated than I expected.
The new query variable DSL editor is only available when you enable the feature toggles.
elasticsearchRawDSLQuery = true
elasticsearchESQLQuery = true
And even then it doesn’t support the old Grafana internal legacy queries:
{ "find": "terms", "field": "type.keyword" }
You have to convert to:
{ "size": 0, "aggs": { "uniqueTerms": { "terms": { "field": "type.keyword", "size": 500 } } } }
And then set the value field/text field directly:
I have raised these UX/docs issues on GitHub.
