How can I publish my Grafana dashboard to the official Grafana.com dashboard catalog?
Hello Grafana Community,
I have created a Grafana dashboard for Raptyra and would like to publish it to the official Grafana dashboard catalog so that other users can discover, download, and import it.
For example, I would like to publish it in the same way as the Node Exporter Full dashboard.
I have been looking for documentation about the publishing process, but I would appreciate some guidance from the community.
Could someone please clarify the following questions?
  1. What are the exact steps to publish a dashboard to the Grafana dashboard catalog?
  2. Do I need a Grafana Cloud account, or is a regular Grafana account sufficient?
  3. What are the requirements for the dashboard JSON file, including the export format and supported Grafana versions?
  4. Are there any requirements for dashboard metadata, screenshots, descriptions, or README documentation?
  5. Does the dashboard need to be reviewed or approved by Grafana Labs before it becomes publicly available?
If there is an official guide or a step-by-step tutorial covering the process, I would be grateful if you could share it.
Thank you for your help!
Hi!
I hope this piece of documentation will help: Share dashboards and panels | Grafana Cloud documentation.
And yes, the dashboards are being reviewed before use; please note there is no specific ETA on when - it really depends on the publishing queue :slight_smile:
