How can i connect to mobile client app?
Facing issue connecting to mobile grafana client, it says error connecting to server, incorrect url or port. How can i find the ip address and port of grafana? which i need for grafana mobile client
Hi @nehakushwaha,
Welcome to the :grafana: community support forums !!
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
