Total run is 1m for Packing in the standart output.But when I add Counter at the end of code.Counter adds the all 50 iteration(5vus * 10 iteration) and gives 3m as a result .As u know per-vu-iterations works parallel so I dont need to calculate all 50 iteration for counter. Only need 10 iteration per 1 user. Because all 5 user runs parallel.How can calculate the time for only 10 iteration per 1 user? I guess this is true for total duration time for my endpoints?
let totalPickingTimeCounter = new Counter("Total Packing Time");
export function setup() {
let createPickingStartedSalesOrdersRes = http.post(
Load.api + endpoints.SalesOrderLoadSeed.CreatePickingCompletedSalesOrders,
JSON.stringify({
salesOrderConfigurations: [
referenceNumberPrefix: "XL-",
amount: 50,
tenant: "test",
headers: {
apikey: "test",
"Content-Type": "application/json",
let operatorAuth = Load.auth(Roles.Operator);
let supportAuth = Load.auth(Roles.Support);
return [
operatorAuth.json(),
supportAuth.json(),
createPickingStartedSalesOrdersRes.json(),
export function handleSummary(data) {
return {
"result.html": htmlReport(data),
stdout: textSummary(data, { indent: " ", enableColors: true }),
const totalVu = 5;
export const options = {
summaryTimeUnit: "s",
scenarios: {
Packing: {
exec: "Packing",
executor: "per-vu-iterations",
vus: totalVu,
iterations: 10,
maxDuration: '35m',
export function Packing(data) {
let tokenForOperator = data[0].access_token;
describe("Packing run", (t) => {
let startTime = Date.now();
let createPackingProcessIfNotExistRes = Load.post(
endpoints.PackingProcesses.createPackingProcessIfNotExists,
tokenForOperator,
JSON.stringify({
pickingToteLabel: `${data[2][(totalVu * (exec.vu.iterationInInstance)) + (exec.vu.idInTest - 1)]}`,
packingAddressLabel: packingAddressLabel,
kpiTrackingProcessId: kpiId,
let cargoPackageTypeBarcodeRes = Load.get(
`${endpoints.PackingProcesses.checkOperationCargoPackageTypeBarcode}?operationName=${createdOperationName}&barcode=${createdBarcode}`,
tokenForOperator
cargoPackageTypeBarcodeTrend.add(
cargoPackageTypeBarcodeRes.timings.duration
let totalPackingTime = Date.now() - startTime;
console.log("data",totalPackingTime)
totalPickingTimeCounter.add(totalPackingTime);
