Hi together,
I have a small but not so nice representation with 2 queries as a graph with auto-y-scaling.
Grafana v10.4.2 with Docker on RPI-Ubuntu-linux -
I have to queries, same time range and same value range.
First with the unit MilliVolt and seconde one with unit Volt.
I want to have one graph with both querie results and the same auto scaling range. -
In the “All” section I set the unit to “Volt”, which represents the Values of the first querry.
For the second querry I used the override option for unit and picked for the second querry “Millivolt”, which represents the Values of the second querry. -
What happened?
See picture.
There is a deviation in the y-axis, -
That the y-axis scaling would the same or a option to use for both the same autorange.
I need the auto scaling effect, so a fixed min/max values for y-axis are not so nice.
Maybe someone has a hint for me.
Thanks in advance, Thomas.
