Histogram plugin installed but getting an error
#1
I’m testing Grafana Hosted (free plan). I’ve installed the Histogram plugin successfully but in the “Add panel” when I try to add an histogram I get the following error:
Plugin Error
Fetch error: 404 Instantiating https://xxx.grafana.net/public/app/plugins/panel/graph/legend Loading > > > https://xxx.grafana.net/public/plugins/mtanda-histogram-panel/histogram_ctrl.js Loading plugins/mtanda-histogram-panel/module
#2
This panel is currently broken, we should remove it from the plugin directory. Use the built in histogram feature in be graph panel (axes tab)
#3
Great, thanks a lot for the quick answer!
