Highlighted Areas in Image
Hello
I have recently updated my Grafana Instance from 7.X (forgot the specific version) to 8.3.6. I am experiencing an issue with a plugin of my own. This plugin worked fine in the 7.X but is currently not working as intended. The plugin uses react-image-mapper2 to create areas in an image that allows redirection upon clicking and highlighting upon mouse hover.
My problem is that, even though I can see the correct (or expected) html, including the map, there are no highlights and the areas are not clickable. I do not think I changed anything between the versions.
Any lead to help fix this issue is appreciated.
Hello @xiaonuno Is it the same issue as discussed here? Href images no longer fully clickable · Issue #36695 · grafana/grafana · GitHub
Thank you for taking your time to help me @mikhailvolkov.
The display was indeed inline but setting it to block did not fix it. But this knowledge might come in handy in the future.
My issue still persists :frowning:
I’ve tried other libraries/modules that help produce similar results and still don’t have a functioning plugin. If anyone have any idea, it would be appreciated :slight_smile:
