Hi fellow Grafana users,
I have a situation, which I want to create some “secondary” dashboards and to use the results from the panels to a “top” layer dashboard. In other words, to share results between dashboards. For example:
Second Level Dashboard:
Panel 1:
Server 1: Disk
Panel 2:
Server 1: App1
Panel 3:
Server 2: Disk
Panel 4:
Server 2: App12
TOP Dashboard:
max(panel_1 OR panel_2 OR panel_3 OR panel_4)
The only way until now that I found is to convert them to Library panels, add them to the top level and aggregate the results there but it’s not quite what I want.
