I’m currently working with grafana 7.3.6
I’m using a double slider and I try to hide number labels.
Didn’t find anything in storybook or else.
Anyone have ideas ?
Thanks
Anyone have ideas ?
Thanks
Some extra information might be useful. Which double sliders? On your own plugin?
Hi
It’s on my own app, I’m using Slider | Grafana Labs with this configuration :
<Slider
min={0}
max={maxValue}
orientation={'horizontal'}
value={[selectionRangeStart, selectionRangeEnd]}
onAfterChange={event => {
this.handleSliderRange(event[0], 0);
this.handleSliderRange(event[1], 1);
I am sorry i was late to reply to you.
I tried to hide it and was able to do it like this:
<Slider tooltipAlwaysVisible={false} min={0} max={255} orientation={'horizontal'}></Slider>
The part that did the trick was tooltipAlwaysVisible
Yeah, I found this but tooltip is visible when you change value
I’m trying to fully disable it
Could you upload an imagen of tour slider?
