Help with UTC Display
Hoping this is a simple issue. Below is an example of my issue. Using the query inspector on a simple elasticsearch query for a date field. The inspector clearly shows the correct expected result returned which was stored as UTC and even returns the correct associated epoch value. However when the Singlestat panel displays the time it converts to local which is EDT (UTC-4). Grafana is configured for UTC and the individual dashboard was also set to UTC, but it keeps converting to local. Any ideas? BTW, I’m on v5.2.3.
John…
There’s an open bug report for this
