Help with Hourly Consumption Graph and Averages in Grafana Using HAProxy Metrics
I am trying to create a graph in Grafana that shows the hourly byte consumption of a specific HAProxy backend over the last 24 hours. Additionally, I want to add a reference line that shows the average of this value over the last 7 days for each hour. To ensure the metric is correct, I would also like to add a third metric that shows the average of this value over the last 24 hours, by hour, for comparison.
Here is what I need to achieve:
  1. First Metric: Hourly growth value of the metric haproxy_backend_bytes_in_total{} over the last 24 hours.
  2. Second Metric: Average of this value over the last 7 days, for each hour.
  3. Third Metric: Average of this value over the last 24 hours, by hour, for comparison.
Problems Encountered:
  • The calculated average is producing linear results, which is not expected.
  • I cannot correctly calculate the hourly average over the last 7 days.
I have attached an image with the current graph and the queries I am using. Here are the queries I used:
Query A: Hourly Consumption Over the Last 24 Hours
sum by (backend) (increase(haproxy_backend_bytes_in_total{backend="app-service_8080"}[1h]))
Query B: Hourly Consumption Over the Previous 24 Hours
sum by (backend) (increase(haproxy_backend_bytes_in_total{backend="app-service_8080"}[1h] offset 24h))
Query C: Hourly Consumption Over the Second Previous 24 Hours
sum by (backend) (increase(haproxy_backend_bytes_in_total{backend="app-service_8080"}[1h] offset 48h))
Query D: Average Over the Last 7 Days
avg_over_time(sum by (backend) (increase(haproxy_backend_bytes_in_total{backend="app-service_8080"}[1h]))[7d:])
Questions:
  1. How can I adjust my queries to get the correct hourly average over the last 7 days?
  2. Is there a better way to structure these queries to achieve my goals?
  3. Any suggestions on how to ensure the comparison data is correct?
Hey folks, any suggestion? I’m stucked with ideias.
Are you using Prometheus?
Is this your setup? Monitor HAProxy with Prometheus and Grafana Cloud | Grafana Cloud documentation.
