Help using a custom config file with a Loki Docker container
I tried changing the default configuration of my Loki Docker container, but if I try to run it with a custom config file it exits with status code 1. What am I doing wrong?
This is my docker-compose.yml file:
services:
  loki-test:
    image: grafana/loki:2.7.1
    volumes:
      - ./loki-config.yml:/loki-config.yml
    command: -config.file=/loki-config.yml
And this is my loki-config.yml file:
limits_config:
  split_queries_by_interval: 3h
frontend:
  max_outstanding_per_tenant: 1024
