Hello, I want to display a time series line graph based on 2 fields.
Field1, Field2.
1 100
0 200
1 123
1 500
0 55
X axis is time, on the y axis, field 2 will be a line graph with Points. However, the point should be displayed in “RED” if field1 is 1 and “GREEN” when field1 is 0.
How can I achieve this?
Thanks in advance
-gv
I was able to solve my issue with a SQL statement.
For those who might be looking for an answer in the future…
SELECT
trade_date “time”
, case when reco = 1 then high else null end buy
, case when reco = 0 then high else null end sell
FROM
model3
WHERE
symbol= ${Symbol) – this is the dropdown filter.
Then in the graph display use
Series Override
set a color for one of the options, and another color for the 2nd (or 3rd) and
And in Stacking and Null Value
Disable to stacking and treat null as NULL.
