Helm Grafana+Prometheus - Alerting GUI - Need to refresh every time
    RKE cluster (Redhat 8.5)
    Rancher monitoring Helm chart BUT changed to use official grafana image.
    Deployed behind an Ingress nginx without subpath (access via grafana.domain.com)
    Create Dashboards with alerts. Trying to create a panel using new CANVAS feature to improve system visualization.
    Deployed Rancher monitoring Helm chart and update grafana from grafana/grafana docker image.
  • What happened?
    From alerts section, i receive 404 not found when i try to view, edit an alert. But if i refresh the webpage, i can access to the rule. Seems to happen when url is /alerting
    Accessing to alerting GUI without refresh.
    Ingress configuration:
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  annotations:
    meta.helm.sh/release-name: monitoring
    meta.helm.sh/release-namespace: monitoring
  generation: 1
  labels:
    app.kubernetes.io/instance: monitoring
    app.kubernetes.io/managed-by: Helm
    app.kubernetes.io/name: grafana
    app.kubernetes.io/version: 9.4.3
    helm.sh/chart: grafana-6.16.14
spec:
  ingressClassName: nginx
  rules:
  - host: grafana.domain.local
    http:
      paths:
      - backend:
          service:
            port:
              number: 80
        path: /
        pathType: Prefix
grafana.ini:
data:
  grafana.ini: |
    [analytics]
    check_for_updates = true
    [auth]
    disable_login_form = false
    [auth.anonymous]
    enabled = false
    org_role = Viewer
    [auth.basic]
    enabled = true
    [dashboards]
    default_home_dashboard_path = /tmp/dashboards/rancher-default-home.json
    [grafana_net]
    url = https://grafana.net
    [live]
    allowed_origins = https://*.domain.local
    [log]
    mode = console
    [paths]
    data = /var/lib/grafana/
    logs = /var/log/grafana
    plugins = /var/lib/grafana/plugins
    provisioning = /etc/grafana/provisioning
    [security]
    allow_embedding = true
    [server]
    root_url = https://grafana.domain.local
    [users]
    auto_assign_org_role = Viewer
    Grafana UI showing the 404 not found page
    no
Thanks :slight_smile:
