i followed the documentation of the developer guideline , and i am building grafana from srouce on the following setup:
OS: Ubuntu 20.04.1 LTS x86_64
Host: HP Notebook
Kernel: 5.15.0-122-generic
Uptime: 7 hours, 41 mins
CPU: Intel i7-7500U (4) @ 3.500GHz
GPU: AMD Radeon R7 / Intel HD Graphics 620
Memory: 1624MiB / 11873MiB
when i ran :
yarn start
I had the following output :
<--- JS stacktrace --->
FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
----- Native stack trace -----
1: 0xe17ec6 node::OOMErrorHandler(char const*, v8::OOMDetails const&) [webpack]
2: 0x123b8c0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [webpack]
3: 0x123bb97 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [webpack]
4: 0x14696c5 [webpack]
5: 0x14696f3 [webpack]
6: 0x14827aa [webpack]
7: 0x1485978 [webpack]
8: 0x1cc0a01 [webpack]
Aborted (core dumped)
Error: Command failed: "webpack" "--config" "scripts/webpack/webpack.dev.js" "--watch"
at genericNodeError (node:internal/errors:983:15)
at wrappedFn (node:internal/errors:537:14)
at checkExecSyncError (node:child_process:890:11)
at execSync (node:child_process:962:15)
at Object.nxExecCommand (/home/wass/grafana/node_modules/nx/src/command-line/exec/exec.js:30:38)
at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
at async Object.handler (/home/wass/grafana/node_modules/nx/src/command-line/exec/command-object.js:11:13) {
status: 134,
signal: null,
output: [ null, null, null ],
pid: 21295,
stdout: null,
stderr: null
