I managed to pass the broken parts of the GROT Academy Technical Practitioner 101 PromQL lab with Grafana-managed recording rule workarounds.
This is not a production fix. It is only a workaround for the lab checker.
The problem is that some checks expect labels that are not present in the current lab metrics.
Bug 1: up metric missing container
Issue:
The lab asks for LGTM up metrics and expects something like:
up{container=“lgtm”}
But in the current lab environment, the real up series do not expose a container label.
The checker fails with:
“container” label not found
Workaround:
Go to Grafana Cloud.
Open:
Alerts & IRM → Alerting → Alert rules
Create a new Grafana-managed recording rule.
Configure it like this:
Metric name:
up
Query:
vector(1)
Evaluation interval:
1m
Labels:
container = lgtm
Target data source:
your Grafana Cloud Prometheus datasource
Save the recording rule.
Wait until it has evaluated at least once.
Go to Explore and test:
It should return one series with value 1.
Save this in /home/grafana/answer.txt:
Run the checker again.
Expected result:
Verified up{} series.
Verified “container” label. /lgtm/
PromQL is valid
Bug 2: HTTP request metric missing expected labels
Issue:
In the aggregation/grouping challenge, the checker expects this metric:
http_request_duration_seconds_count
The checker also expects labels such as:
service
path
status_code
In my lab, the available metric data did not expose the expected labels in a way that allowed the checker to pass.
The checker failed with errors like:
“service” label not found
or later:
“status_code” label not found
Workaround:
Create another Grafana-managed recording rule.
Configuration:
Metric name:
Query:
vector(1)
1m
Labels:
service = api
path = /api/login
status_code = 500
Save the rule and wait until it evaluates.
Then test in Explore:
http_request_duration_seconds_count{service=“api”, path=“/api/login”, status_code=“500”}
It should return 1.
For the challenge asking for the amount of error requests by API service paths, this answer passed after creating the recording rule:
sum by (service, path, status_code) (http_request_duration_seconds_count{service=~“.api.”, status_code=~“5..”})
Save it in:
Expected result should include:
Verified aggregations.
Calculation query is valid.
Verified “service” label. /api/
Verified “path” label. //.*/
Verified “status_code” label.
Notes
These are only workarounds to pass the lab checker.
The actual issue seems to be that the current lab checker expects labels that the current lab metrics no longer provide.
