i will create and use the Grappa panel plugin.
However, if i reduce and save the panel size, it will be restored.
I want to make it as small as possible, but how can I fix it?
I also wonder if the panel can be hidden.
display: none as css; Using the option also affects other panels.
Can I hide only the panels I want?
