I’m using grafana as part of srsRAN (srsRAN. It worked perfectly until I wanted to learn more about grafana. Now I get the following error:
$ sudo docker compose -f docker/docker-compose.yml up grafana
[sudo] password for sep5g:
WARN[0000] /home/sep5g/20240605/srsRAN_Project/docker/docker-compose.yml: `version` is obsolete
[+] Running 3/0
✔ Container metrics_server Running 0.0s
✔ Container influxdb Running 0.0s
✔ Container grafana Created 0.0s
Attaching to grafana
grafana | logger=grafana.update.checker t=2024-06-07T13:38:05.567329964Z level=error msg="Update check failed" error="failed to get latest.json repo from github.com: Get \"https://raw.githubusercontent.com/grafana/grafana/main/latest.json\": dial tcp 185.199.108.133:443: i/o timeout" duration=10.00103396s
grafana | logger=plugin.signature.key_retriever t=2024-06-07T13:38:05.597621864Z level=error msg="Error downloading plugin manifest keys" error="Get \"https://grafana.com/api/plugins/ci/keys\": dial tcp 34.120.177.193:443: i/o timeout (Client.Timeout exceeded while awaiting headers)"
I have purged grafana and tried to remove all traces of it, but still I get the same error. The srsRAN community can’t help, so maybe someone in the grafana community has a clue?
