Grafana with cyberpanel and litespeed server
I install grafana using following commands.
sudo apt-get install -y apt-transport-https software-properties-common
wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
sudo apt-get update
sudo apt-get -y install grafana
sudo systemctl enable grafana-server
sudo systemctl start grafana-server
Also add datasources.yaml file.
This worked properly. After that I install CyberPanel. Then I add TCP Port 3000 to firewall. But now it is not loading x.x.x.x:3000 not loading. How to solve this issue?
Error message is
ERR_CONNECTION_REFUSED
When I check processing task, grafana use high CPU and Ram.
Prometheus is data source and it is working properly.
These are log file data:
