After delete some variable on dasboard the are still selectable and new variable are not selectable.
Please help where to correct this ??
Can you share a screenshot, also did you restart your server (which version btw).
Good Luck
I just found the solution.
If you save your dasboard with the save variable selected then it stay active.
Also if you after this save remove the variable
So after you remove the saved variable you must save again your dasboard with tha variable you have choosen.
Then the deleted variable is gone.
