I think I have found a bug with the table visualisation.
Grafana V8.4.7 | AWS Managed Grafana Service
Windows 10, Microsoft Edge
Visualisation: Table
I want to apply a value mapping to a calculated field with negative values. -
Using an overide property on the field selected by name, apply the following value mappings:
[1 - 100] → Template Not Found
0 → Current Version
[-1 - -100] → New Template Available -
What happened?
The first two value mappings applied, as per screenshot. However the negative values did not apply and the cels were unchanged.
Values from -1 to -100 should have been changed to say “New Template Available” -
No errors found in the console. -
Configure value mappings | Grafana documentation
