Hi
I receive data on zabbix api, it is possible to receive a notification to send to telegram?
Hi
You will have to build some sort of API which can receive data over API and then you can user probably python to send that data to Telegram using Python. I am telling python, because it is very easy to do that in python language.
If you are interested to know the steps, you may follow this link here:
