Anyone has seen below error , how to fix this?
When I click on sign it with microsoft , first time i get this error (attached) and 2nd time I am able to login.
We have LB and two host associated with this?
LB - Alpine Partners
My grafana ini file on one host , same on other except root url has qe-1
#################################### Server ##############################
[server]
# Protocol (http, https, h2, socket)
protocol = https
# Minimum TLS version allowed. By default, this value is empty. Accepted values are: TLS1.2, TLS1.3. If nothing is set TLS1.2 would be taken
min_tls_version = ""
# The ip address to bind to, empty will bind to all interfaces
http_addr =
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = localhost
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
enforce_domain = false
# The full public facing url
root_url = https://zbx01-grafana-poc-qe-0.az.statup.com/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
#serve_from_sub_path = false
serve_from_sub_path = true
What happened?
