Please see image below. I try to have a monthly overview with the total production per day
This is the configuration of the panel:
It is representing the average load per day. How can I calculate the total consumption per day in this monthly view ?
Thanks a lot for putting me on the right track !
Kr,
Bart
Has aynyone got an idea how to solve this ? Thank you very much in advance !
Can you change the mean selector to total?
Hi @superknight,
Thanks for your answer. Unfortunately there is no ‘total’ available in the selector.
Any other ideas ?
Kr,
Bart
Sorry, I did know that. Are you able to use sum to achieve your desired result?
Hi @superknight
Then I got this:
That would be nice, but not correct
