Grafana query for top 10 cpu process
  • What Grafana version and what operating system are you using? Linux os , version is 8.1.8
    I would like build prometheus query for top 10 cpu process . I have host with multi core ( some of them have 8, 4, 23 etc) . I would like build prometheus query for top 10 cpu process . I have host with multi core ( some of them have 8, 4, 23 etc) . but somehow for host who’s having 8 or 23 core, grafana dashboard for percent goes to more than 100 %
    Above is way I’m using to achieve
  • What happened?
    Grafana dashboard for percentage goes beyond 100% .
I would like dashboard should not go above 100% irrespective of core.
. I’m using below query
" topk (10, (avg (irate(namedprocess_namegroup_cpu_seconds_total{instance=”<>"}[1m]) ) by (groupname) * 100) " It giving partially correct output but as mentioned above for multicore Y axis goes more than 100 %.
No
    Prometheus documentation.
