Grafana pod container is in CRASHLOOPBACKOFF state
Hello Everyone,
I have deployed my kube-Prometheus-stack helm chart on k8s, everything was working fine but today suddenly my Prometheus-stack-grafana pods gone in
CrashLoopBackOff state
, when I checked it was not able to create grafana container and got below warning in grafana-container logs, anyone face this issue previously ?
Any suggestion/solution will be great help.
warning message below:
logger=sqlstore t=2022-09-26T13:37:18.08+0000 lvl=warn msg=“SQLite database file has broader permissions than it should” path=/var/lib/grafana/grafana.db mode=-rw-rw---- expected=-rw-r-----
panic: New alert rules created while using unified alerting will be deleted, set force_migration=true in your grafana.ini and try again if this is okay.
status of pod:
monitoring-stack-grafana-6db47cxxxx 2/3 CrashLoopBackOff 26 110m
monitoring-stack-grafana-f4954xxxxx 2/3 CrashLoopBackOff 9 25m
Old post but linking the right post thread to it:
