Grafana "Paste panel" is grayed out
I have this issue in Grafana v9.5.5 where the paste panel seems to be grayed out.
Hi @thepiemonster,
Thanks for opening this post.
Can you please try to reproduce this same issue on https://play.grafana.org/ ?
Thanks
Hi @usman.ahmad @thepiemonster,
I’m experiencing the same issue after upgrading from Grafana 10 to 11.
I also tested it in the Grafana Playground and observed the same behavior—the button is greyed out.
Are there any options to modify this behavior?
Try different browser/disable browser plugins/… There is very likely something on the browser side, what is blocking that feature.
Thanks for the answer.
I tried out with Chrome and Edge. Still the same issue. Before the update, these were working. Does the “paste panel” button work for you on the Grafana Playground?
Yes, it works on my computer, in my Firefox.
There was an missunderstanding on the developer side. Everything works properly.
