Grafana OSS Vulnerability - Need Fix For latest v10.4.1
Looking for the vulnerability fix for the latest OSS v10.4.1 and below are the CVE IDs
CVE ID Compliance ID Type Severity Packages Source Package Package Version
CVE-2023-6992 46 OS medium zlib 1.3.1-r0
CVE-2024-25629 46 OS low c-ares 1.24.0-r1
CVE-2024-2511 46 OS low libssl3,libcrypto3 openssl 3.1.4-r5
CVE-2016-10735 49 javascript moderate bootstrap 2.3.2
CVE-2018-14040 49 javascript moderate bootstrap 2.3.2
CVE-2018-14042 49 javascript moderate bootstrap 2.3.2
CVE-2018-20676 49 javascript moderate bootstrap 2.3.2
CVE-2018-20677 49 javascript moderate bootstrap 2.3.2
CVE-2024-28180 416 go moderate github.com/go-jose/go-jose/v3 v3.0.1
GHSA-3m87-5598-2v4f 416 go moderate GitHub - prometheus/prometheus: The Prometheus monitoring system and time series database. v0.49.0
CVE-2024-28180 416 go moderate gopkg.in/square/go-jose.v2 v2.6.0
CVE-2023-45288 416 go moderate The Go Programming Language v0.20.0
Please can you give details of how this security scan is being performed?
Specifically:
  • which tool is being used to do the checks?
  • are you checking what is installed on a server, or how it responds over the
    network?
  • if it’s over a network, do you have adequate / standard firewall rules in
    place in between the checker and the Grafana system?
Antony.
