I am working with Multipass and microk8s on Mac and I want to build a dashboard for our local dev env.
It seems that I cannot find grafana-cli on my VM so I cannot install anything (charts, apps, plugins, etc…).
Is there a workaround for this env? maybe copy-pasting the lib directly to the VM?
Thanks
How did you install Grafana? Are using Grafana’s docker image?
Otherwise, you could absolutely copy/mount the plugins into the Grafana plugins directory.
