Hi Everyone.
I’m having a strange problem, and I’m not sure if it’s Grafana itself, but I’ll give it a try and ask. I’ve installed Grafana * v6.5.2. on installed computer everything works just perfectly but in local network it is not available doing “community.grafana.com”.
You need to use the IP address of the machine running Grafana. Like so:
http://192.168.0.57:3000
You can find the IP address with “ipconfig” on a Windows system and “ifconfig” on most Unix-like systems.
HTH,
Patrick
tks @pmhausen it was the Windows defender Firewall blocking Grafana, i just disabled it and it worked
I seriously doubt it works with http://grafana.staged-by-discourse.com/ even with the Windows firewall disabled.
So which URL are you using?
