Grafana login redirection loop
    grafana docker image 8.5.10
    Deploy grafana as an ecs fargate task behind AWS ALB.
  • What happened?
    After logging in browser is redirecting to /login
    Successful login
    logger=context traceID=00000000000000000000000000000000 t=2022-08-09T09:23:37.69+0000 lvl=eror msg=“Failed to look up user based on cookie” error=“user token not found”
    No.
Do you mean you have to reconnect every time ? your auth cookie is been deleted ?
can you provide more info.
i you arlredy connected your browser should store auth cookie
Hi alexandrearmand, please find the screenshot below, login call is giving a 200 with grafana_session cookie but after that browser isn’t redirecting to dashboards but redirecting again to login page
After logging in once if I change the url to /dashboards it works.
I’m not sure about this, could you create your own user ?
admin account have specific rules
maybe related to AWS.
@alexandrearmand Thanks for your help, it was due to autocommit being off on the mysql database behind grafana, the tokens generated weren’t getting persisted after login I guess so subsequent calls were not being authorized.
