I tried fresh installation of grafana and trying to access the console. It gives me “ERR_CONNECTION_TIMED_OUT” in chrome. Tried with other browsers too and it fails. The version i installed is “5.0.4-1”. I dont see any error messages in grafana.log. enabled the debug mode to check for info but no luck there. validated from “curl” and it works from my system…
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
Set-Cookie: grafana_sess=3b6ab5933e6ad3c1; Path=/; HttpOnly
t=2018-04-06T11:17:54-0500 lvl=info msg=“Starting Grafana” logger=server version=5.0.4 commit=7dc36ae compiled=2018-03-28T06:52:41-0500
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2018-04-06T11:17:54-0500 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2018-04-06T11:17:54-0500 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2018-04-06T11:17:54-0500 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2018-04-06T11:17:54-0500 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2018-04-06T11:17:54-0500 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2018-04-06T11:17:54-0500 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2018-04-06T11:17:54-0500 lvl=info msg=“App mode production” logger=settings
t=2018-04-06T11:17:54-0500 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=114742
any help here, appreciated. Thanks
