Grafana integrating with TRAFIP
Hello there, we are trying to integrate Grafana with a flow analyzer named TRAFIP.
Somebody has already heard about it? Is that possible? Witch plugins or databases should I use?
Thanks!
There is currently no plugin for TRAFIP. There is one for ntop which is based on the Simple JSON Data Source plugin. So if TRAFIP has an API you could build a similar plugin.
Another approach would be to pull data from TRAFIP and save it in a db. I don’t know anything about TRAFIP so no idea how you would do that.
Thanks man, I’ll see this Json plugin or try to get its db and collect the traffic.
