I am trying to host Grafana (as well as a few other logging tools in a sidecar pattern) in an Azure Container App, and I’ve been having an issue where the container appears to start correctly, but when I go to the URL the page just loads forever until it eventually times out.
My setup is fairly basic at the moment, pulling the latest image from docker.io and setting a few environment variables. While I am also using Front Door as a reverse proxy (and have followed the guide on accessing Grafana behind a reverse proxy), neither the Front Door URL, nor the direct container URL work.
There are no obvious errors in the console or system log, there’s a lot of logs to post so if you need any in particular let me know. And Azure is reporting the container revision and provisioned and started.
Is there anything else I can check or change to get this working?
I have been using this GitHub project as a basis and making my own customisations: GitHub - kimcuhoang/practical-net-otelcollector: Practical .NET Observability with OpenTelemetry Collector
The bicep file I am using to deploy (with some slight redactions):
param containerResources object = {
cpu: '0.25'
memory: '0.5Gi'
resource containerApp 'Microsoft.App/containerApps@2023-05-02-preview' = {
tags: {
'Resource-Name': <containerAppEnvironmentName>
'Resource-Description': 'Containerised application hosted in a managed container environment'
'Platform-Environment': substring(resourceGroup().name, 0, 3)
identity: {
type: 'SystemAssigned'
properties: {
managedEnvironmentId: <containerAppEnvironment>.id
configuration: {
activeRevisionsMode: 'Multiple'
ingress: {
external: true
allowInsecure: false
targetPort: 3000
transport: 'auto'
traffic: [
weight: 100
latestRevision: true
template: {
revisionSuffix: <containerRevision>
containers: [
image: 'jaegertracing/all-in-one:latest'
resources: {
cpu: containerResources.cpu
memory: containerResources.memory
image: 'grafana/loki:latest'
args: ['-config.file=/etc/loki/local-config.yaml']
resources: {
image: 'prom/prometheus:latest'
args: ['--config.file=/etc/prometheus/prometheus.yaml', '--web.listen-address=:8080']
resources: {
env: [
value: '/etc/prometheus/prometheus.yaml'
image: 'otel/opentelemetry-collector-contrib:latest'
args: ['--config=/etc/otel-collector.yaml']
resources: {
image: 'docker.io/grafana/grafana:latest'
resources: {
volumeMounts: [
volumeName: 'logging-app-storage'
mountPath: '/etc/grafana/provisioning/datasources'
env: [
value: basePath
value: '${basePath}/logging/'
value: 'true'
volumes: [
storageName: 'logging-app-storage'
storageType: 'AzureFile'
