Grafana in AWS EC2 with subdomain and SSL
First, thanks for create Grafana, its a complete platform.
I’m currently use Grafana 4.4.1 on AWS EC2 instance running Windows Server 2012 R2.
How could I add it to Internet information services and install a SSL certificate to use https protocol?
And I have a domain in Godaddy, is it possible to have a subdomain like grafana.example.com pointing to the AWS EC2 IP address?
Thanks for your help!
SSL:
1.) Configure your Grafana
Doc is your friend - http://docs.grafana.org/installation/configuration/#cert-file
2.) Cloud native solution
Configure your SSL cert in AWS ELB which will be used in front of your Grafana
DNS: yes, you can. It’s just only about configuration of additional DNS record.
Hi!
I create a ELB certificate, how can I add it to Grafana?
I understand that you need to configure https protocol, cert_file and cert_key where can I find it?
Thank you!
