My configuration:
- Grafana v8.3.2 free version
/var/lib/grafana
- Grafana Image Renderer plugin v3.3.0
/var/lib/grafana/plugins/grafana-image-renderer
- CentOS
I can’t set a custom config file on my system. The Image renderer plugin works. However, if I create a config.json
file (and restart the Grafana service), the Image Renderer plugin will not work. It will only work again if I reinstall the plugin.
I would like to change the default language to Hungarian, because the plugin is render all numbers in not my country’s format.
I read the documentation:
I don’t understand that how could I set up the config.json if I don’t use Docker? I don’t need to start a plugin service, it runs anyway, but I can’t found the usage of the config.json.
What is the problem?
