Grafana HTTPS server inquiry
    Windows Server 2022
    Have Grafana read the Grafana HTTPS cert from the Windows Certificate Store
    I would like Grafana to read the custom.ini, read the SHAKE/SHA256/SHA1 digest of the HTTPS certificate in question, and then read the HTTPS cert from the Windows Certificate Store.
  • What happened?
    Nothing.
