I wonder if there is a better way to do this? Since lets encrypt is owned specifically by root I had to copy the key files the same way and give it proper permissions, but there must be a better way?! The only problem I had was trying to point to my key files in /etc/letsencrypt/… without compromising my certs permissions of course
Hi All,
I have generated .csr and .key file in grafana server and gave .csr file to our CA team to get this signed. When CA autority signed this they gave me 3 file in .crt format(Server.crt, Intermediate.crt and Root.crt). I am not sure how to use this file in grafana. For now i am using below configuration but this is not working. Can someone help me on this how to do the setup.
cert_file = /etc/grafana/crt/ServerCertificate.crt(CA signed certificate)
cert_key = /etc/grafana/server.key(this one is first file that i created using openssl command )
Thanks,
Srikanta
Thank you so much. I can’t believe a relatively basic use case like this isn’t explained elsewhere. Yours is the only solution that I’ve found to work!
Hey zigobs, I have been trying to set things according to the explanation that you have given. I am new to grafana. However, I am unable to get the solution working on my EC2. Can you explain the steps clearly and mention everything step by step?
I have installed httpd, mod_ssl, and certbot to create the SSL certificate.
The https link says “Your connection is not private” and does not load the grafana page.
I dont have etc/grafana folder.
After installing Grafana, I have C:\Program Files\GrafanaLabs\grafana
So where exactly I should keep cert and key file?
I am also stuck on the same problem. Did you get any solution?
any solution identified for this?
Not sure if this is the problem, but for those with Grafana on Windows this is what I figured out. The cert_file, cert_key, and related options have to point to the correct path in quotes. eg cert_file = “C:\somepath\to\your\certfile.pem”
Can this be closed and redirect to a wiki if solved by people above while others like myself are struggling to make sense?
This worked for me:
sudo setfacl -R -m u:username:rX /etc/letsencrypt/{live,archive}
As i understand we need to move cert files in /etc/grafana folder is it ?
Correct. I just set this up on Debian a few months ago and it works fine if you place the cert files in /etc/grafana
Could you share the solution?
Dear all,
we now have official documentation that details how to set up Grafana HTTPS for secure web traffic:
