Grafana Geomap Projection for
When using Geomap, is there a way to change the projection of the view? Instead of seeing 2D view, I want to see a 3D view of my basemap? I am using Mapbox for my basemap and I want to be able to control my basemap view by using my mouse.
Yes I guess this some what. How did you adjust the view angle? Is there a way to change the view angle by using the mouse/keyboard?
you can any use mouse, pen, touch screen whatever to pan zoom in zoom out
Could you provide steps how to do this? I emailed Grafana support they said there isnt a way to do it. So im glad you have figured a way.
Also on mapbox map, did you use the url method from mapbox studio or a different way? Because i didnt see mapbox as a plugin for Grafana.
this is the plugin I used. read up the doc and should guide you to end goal
I am new at this. I have installed the business Chart plugin. I assume that under JSON, I have to paste my mapbox code from the style.json under the Code dropdown menu? I tried doing that, but I am getting an ECharts Execution Error Unexpected token ‘:’. Any help with this error?
Check this thread out
