Grafana for finance - compute XIRR?
    Grafana for docker. Grafana v11.6.0 (d2fdff9ee4)
    I have cashflow information in a mysql database (dates and cash-flows). I would like to have Grafana calculate the IRR (Internal Rate of Return) for these cash-flows.
    Computing these in mysql is very complicated (I have given up). If I could use Grafana to aggregate these columns and output IRR, it would be great.
  • What happened?
    n.a.
    n.a.
    n.a.
    n.a.
    Tried to look for IRR / XIRR and Grafana but no dice.
please share DDL and DML and sample data and the result you want from the sample data
Here follows a sample excel file with some data and the calculations I am doing. This data is exported from a mysql
This is an export from the following table:
CREATE TABLE `transactions_with_simulations` (
  `Carteira` varchar(255) DEFAULT NULL,
  `Legal Entity` varchar(255) DEFAULT NULL,
  `Intermediary Name` varchar(255) DEFAULT NULL,
  `Google Ticker` varchar(255) DEFAULT NULL,
  `Yahoo Ticker` varchar(255) DEFAULT NULL,
  `Unit Flow` double DEFAULT NULL,
  `Trx Date` varchar(255) DEFAULT NULL,
  `Unit Value` double DEFAULT NULL,
  `Unit Commissions` double DEFAULT NULL,
  `Unit Stamp Duty` double DEFAULT NULL,
  `Cash-flow` double DEFAULT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_0900_ai_ci;
