Please help me how to construct query in Grafana Explorer
if i need particular one of parameteres given here
for example i need only host=“database”
when i do nginx_ingress_controller_request_duration_seconds_bucket (host=“database”) it says wrong syntax
nginx_ingress_controller_request_duration_seconds_bucket{app_kubernetes_io_name=“ingress-nginx”, app_kubernetes_io_part_of=“ingress-nginx”, controller_class=“nginx”, controller_namespace=“ingress-nginx”, controller_pod=“nginx-ingress-controller-d4fc54”, host=“database”, instance=“bla_bla”, job=“kubernetes-pods”, kubernetes_namespace=“ingress-nginx”, kubernetes_pod_name=“nginx-ingress-controller-d4fc54b49-555mc”, le="+Inf", method=“GET”, namespace=“database”, path="/", service=“database-frontend”, status=“200”}
What happened?
Did you follow any online instructions? If so, what is the URL?strong text
I appreciate that you reacted to my question
i am using Ingres for kubernets 1.16
Please help me I will be very grateful to you
i am writing in query metrics Prometheus in Grafana to query ingress endpoint written in Kubernetes i have paths like /api /api/documents /api/database
histogram_quantile(
.5,
sum by (le, “//api”)(
rate(
nginx_ingress_controller_response_duration_seconds_bucket{
ingress =~ “$ingress”, path = ~"//api"
}[1m]
Grafana checks and syntax is ok but still it does work does not produce any graph
Could you be so kind to hint me where can i find how tor write paths with regular expression
because if i write
histogram_quantile(
.5,
sum by (le, path)(
rate(
}[1m]
it works ok
Please give me a hint what is wrong how to deal with that
Be healthy and strong!
Anatoli Guliaev
Kiev
Ukraine
сб, 30 окт. 2021 г. в 02:37, Grant Pinkos via Grafana Labs Community Forums <grafana@discoursemail.com>:
I thank you for your answer
Sure i attached screenshots i have
If you know a bit more or somehow you can help me i will never forget it
the question is
there’s a API application in 12 pods of kubernetes
How can I pull the number of http queries
going to application
in grafana not just by paths written in ingress
but by different regular expressions like
/api/baza/operation/(?P<operation_id>[^{}/]+)
how can you pull them out, maybe know where to find info
i think i have kuber standard metrics, but i don’t know how to collect them in grafana from an application
within the pod of kubernetes
With respect
Anatoli Guliaev
Keiv
пн, 1 нояб. 2021 г. в 11:05, Grant Pinkos via Grafana Labs Community Forums <grafana@discoursemail.com>:
I think you need each of these items to be set up as separate variables. From your screenshots, it appears you have only 2 variables: Datasource and Service Ingress.
Grant !
Thanks for answering me
I even made screenshots you asked
where i am getting error
Please look at them and I ask you for help where can i find how to write by path = /api/documents in Grafana right syntax may be i need //\ some construction
Please help me
пн, 1 нояб. 2021 г. в 14:47, Grant Pinkos via Grafana Labs Community Forums <grafana@discoursemail.com>:
